Date/Time: Fri, 03 May 2024 11:13:20 +0000
[User Discussion] - Extend Linear Regression End Channel
View Count: 1010
[2019-06-25 18:16:30] |
User439067 - Posts: 48 |
Could we get the ability to extend the lines this study produces?
[2019-06-25 19:59:53] |
Extend in what way? Do you want the lines to extend to the right edge of the chart?
[2019-06-25 20:11:49] |
Yep that's what I'm wanting.
[2019-06-26 10:14:16] |
Use this Draw Style: Chart Studies: Line Extend To Edge (ACSIL: DRAWSTYLE_LINE_EXTEND_TO_EDGE) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-26 14:28:21] |
Any way to continue the slope of the line? That's what I'm looking for.
[2019-06-27 04:15:42] |
No this is not supported. It is not something we could add any time soon.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-27 04:15:54
