Date/Time: Thu, 02 May 2024 06:01:58 +0000
I WANT TO BE ABLE TO SEE STOCKS
View Count: 1576
[2019-06-23 19:12:58] |
User384999 - Posts: 28 |
as an example TSLA I cannot see this with the sierra charts all data service or fxcm demo also want to see uk stocks what data feeds do I need to see this kind regrards chris |
[2019-06-24 18:41:23] |
You definitely can get US stock data. Update Sierra Chart to the current version: Software Download: Fast Update That should not be necessary but it is just standard practice for us to say that if someone is having a problem with something in case for some unknown reason there is an issue in a prior version with what they are doing. We do periodically make updates with how market data is handled and maybe there is some issue in the version you are running. Just follow the instructions here to open a chart: Getting Started, Opening Charts and Basic Trading: Open Chart And enter the symbol TSLA. For UK stocks the symbols are here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=2#LSE If you need further help, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-24 18:50:37
[2019-06-25 17:41:44] |
thankyou this is now solved kind regards
