Date/Time: Thu, 02 May 2024 10:47:18 +0000
Delete/remove chart bars
View Count: 903
[2019-06-22 02:50:38] |
User996085 - Posts: 6 |
On the FDAX chart, how can l remove the 1st 5 hours of pre-open bars (that is 8:15 AM to 1:15 Pm UTC+8:00) from the chart? Thank you, NiƱa |
[2019-06-23 05:49:43] |
This is accomplished through adjusting the Chart Session Times. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
