Date/Time: Tue, 30 Apr 2024 00:28:50 +0000
Hello, I purchased a $35 100 market-depth data service.
View Count: 570
[2019-06-21 16:16:43] |
User958854 - Posts: 3 |
Hello, I purchased a $35 100 market-depth data service. Why is it still only showing 10 layers?
[2019-06-21 17:19:11] |
SC Support - Posts: 1795 |
To control the number of market depth levels that are subscribed to, select Global Settings >> Data/Trade Service Settings >> SC Server Settings. The setting is: Max Depth Levels. After changing this setting, reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers It is recommended to set this only to what you require. The higher the setting the more bandwidth usage. If you want to get all market depth levels, set this to 0. One nice feature about this extended depth is now there is the ability to control the number of market depth levels received by Sierra Chart anywhere all the way down to a single level. |
[2019-06-21 19:15:29] |
Can you tell us what symbol you are seeing 10 levels of market depth for? Assuming you are still having a problem. Also update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-21 19:16:07
