Date/Time: Sun, 28 Apr 2024 21:03:13 +0000
default sound for symbol price alerts set from the chart
View Count: 630
[2019-06-20 14:20:06] |
User170575 - Posts: 221 |
Hi---seems like it should be under General settings---Alerts/General3? Thx Cy |
[2019-06-21 03:59:20] |
We do not understand what the particular question is here. Still, here are some thoughts that could help you: - The symbol alerts page allows you to select the particular alert associated with that symbol alert. - Like any alert, the sound associated with the Alert Number chosen for the Symbol Alert can be changed/set on the General Settings >> Alerts window. Refer to the following for setting the alert sounds: General Settings Window: Configuring Alert Number Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-21 13:22:55] |
ok---so it defaults to alert1 every time the alert window is open---it would be cool if you could change the alert number and it would stay as the default when the alert window is opened the next time---no worries---I have a work around many thx and have a nice weekend |
[2019-06-21 13:37:32] |
Do you mean the General Settings window defaults to Alert 1? Yes we can certainly change that and remember the previous selected Alert Number.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-21 13:37:50
[2019-06-21 13:53:28] |
"add symbol alert"---I set the alert form the chart
[2019-06-24 00:48:48] |
Ok we will look into this.
