Date/Time: Fri, 03 May 2024 21:03:49 +0000
order problem
View Count: 529
[2019-06-19 19:48:17] |
User873130 - Posts: 44 |
Hi I had a position in a futures market while my internet connection was off that was filled without sierra chart running. Now when i open a new position and close the position, i get very strange fill orders. Any way to reset the position of my orders? thanks |
[2019-06-20 02:52:27] |
This is not clear for us. Specifically what are you referring to? Can you attach a screenshot of what you are referring to. However, refer to this page: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-20 02:54:00
