Date/Time: Sat, 04 May 2024 00:56:08 +0000
How to start Tick bars? ie Aggregation type:Tick, aggregation period:100 ticks
View Count: 1126
[2019-06-19 17:32:46] |
jy - Posts: 6 |
Good afternoon, I am unable to find in settings the aggregation type TICK and aggregation period 100 Ticks. I see range bars with ticks and renko bars with ticks but not a tick based aggregation period. If not I would appreciate some help with setting up chart bars based on tick change Thank you |
[2019-06-19 18:43:15] |
Refer to this Bar Period Type: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-19 22:47:20] |
jy - Posts: 6 |
Thanks for your time. I am new at Sierra and I really like it and it may be the ultimate solution for me if I can solve a few major issues along the way. You recommend choosing Number of Trades-per-bar as a solution to my question. With respect, a Trade-Per-Bar is not the same as a Tick Per Bar. Every trade is not a always a Tick, there could be 100 contracts traded at a certain one tick level without a change in Ticks. Is this maybe why this trade-per--bar option does not bring up the same Tick CHart as any other chart provider would display. Any other thoughts? Am I missing something? Kind Regards |
[2019-06-19 22:55:38] |
cmet - Posts: 537 |
All standard tick charts are based on number of trades.
[2019-06-19 23:52:07] |
Sawtooth - Posts: 3993 |
Maybe you want to use the 'Price Changes Per Bar' bar type:Chart Settings: Price Change Bar |
[2019-06-20 04:00:08] |
We are fairly sure you do want Number of Trades per Bar. The other thing we would add is to set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-21 10:22:49] |
jy - Posts: 6 |
That's the issue I am having. Trade number is not the same as Tick Chart; there could be 10000 block trade at a certain tick without a single tick change.
[2019-06-22 02:56:18] |
It is still not clear exactly what you need. The only Bar Period Types which match what you want or close to what you want are as follows: Number of Trades Per Bar Price Changes Per Bar Volume Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
