Date/Time: Fri, 03 May 2024 10:30:43 +0000
Question if Server is down
View Count: 761
[2019-06-18 18:07:02] |
rahul - Posts: 160 |
Hello, I am thinking of trading 24/7 through my automated study. Since I won't be in front of the PC, does the backup servers (4 and 1) automatically kick in when an order is sent and server 2 (primary server) is down for that second? Basically when the order fires, and the server is down, I want it to re-fire when the server comes back online instantly. What piece of code do I need to add to my study? |
[2019-06-18 19:46:58] |
does the backup servers (4 and 1) automatically kick in when an order is sent and server 2 (primary server) is down for that second? Yes if these are the backup servers you have specified.However, there is no order retransmission. We do not regard that as safe. Also, it is unlikely that an order is going to be sent right at the moment when a server is down and there is a reconnection occurring. If a server is down there is going to be a reconnect to the next available server. And a server going down is very unlikely to begin with. What piece of code do I need to add to my study? You have to work out the details of resubmitting order yourself.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 19:47:37
[2019-06-18 22:01:26] |
Thanks for your reply. 1. Firstly, are the servers configured correctly? Primary = Server 2; Backup 1 = Server 4; Backup 2 = Server 1? 2. Are you saying that since I have backup servers I don't need check for this in my code? My order is only sent on Bar Close, so if there is enough of a delay, then the new bar will start and the code will skip the trade. Since these trades can go on for days, I would miss a critical entry / exit. If I do check for this, should I create a recurring loop till the result = 0? Is this the right approach? if (Buy == true) { do { Result = sc.BuyEntry(NewOrder); }while (Result != 0) } |
[2019-06-19 03:18:05] |
Use: Primary = Server 2 Backup 1 = Server 1 Backup 2 = Server 4 Definitely do not put a loop like that!!! For more information about error handling, refer to: Automated Trading From an Advanced Custom Study: SCTRADING_ORDER_ERROR Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 03:18:53
[2019-06-20 01:25:47] |
Thanks for the server configuration. Regarding the error handling, I will check if Result > 0 is true, then proceed to set flags = true in my code. If Result = SCTRADING_ORDER_ERROR, then flag = false (reset all variables to 1 bar back value, and don't copy over current bar value as trade didn't execute). I use to flags to check if I am already in the trade |
