Date/Time: Sat, 04 May 2024 19:41:21 +0000
Depth bars not saving once Sierra closed
View Count: 666
[2019-06-18 10:00:01] |
User663078 - Posts: 13 |
Hi Support, Can you please advise on how to safe the depth bars, as currently they do not save when Sierra is closed. regards BL |
[2019-06-18 15:16:50] |
This is something we are working to solve. We expect to have this done within a few weeks. For now you need to set the Source Data Input with that study to use the Historical Market Depth data with that study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=213&Name=Bid_Ask_Depth_Bars#Inputs In this case the study will use the saved market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 23:26:29
[2019-06-19 21:03:26] |
Thank you, Apologies but I can't find the option on my chart, can you please point me to the exact location sorry about this. |
[2019-06-20 18:39:20] |
It is called "Source Data" and it is a study Input. Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
