Date/Time: Thu, 02 May 2024 08:42:19 +0000
Large Volume Trade Indicator
View Count: 879
[2019-06-12 06:25:06] |
TradingMarketProfile - Posts: 120 |
This Input specifies the volume that a trade needs to be greater than or equal to for it to be considered a large volume in this sentence i would like to be sure that the "a trade" is for one trade or a cumul of trade. Thanks Thierry |
[2019-06-12 21:28:37] |
This depends upon the underlying data feed being used. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-12 21:28:42
