Date/Time: Sun, 12 May 2024 07:36:37 +0000
Sierra Chart CTS
View Count: 945
[2019-06-11 21:42:56] |
rwilliams1 - Posts: 339 |
I'm using Sierra with Amp trading and CTS T4. 1. Which CTS should I use for logging in? The CTS T4 Fix or the CTS Trading DTC? 2. How do I pull up spreads in SC with CTS T4? I don't see them listed in the symbols window. Thanks |
[2019-06-12 00:01:05] |
1. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions You will not use the DTC connection. That has been discontinued for CTS. 2. Refer to: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#Symbols 3. Please also be aware of this new service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
