Date/Time: Sun, 12 May 2024 16:03:59 +0000
DateTimeString to SCDateTime
View Count: 925
[2019-06-11 10:41:17] |
PK - Posts: 12 |
Hi, I cannot find the function of converting DateTimeString into SCDateTime, could you please point it out where is it in your documentation? Thanks. |
[2019-06-11 17:03:04] |
There are two separate functions. Refer to: sc.DateStringToSCDateTime() sc.TimeStringToSCDateTime() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-12 00:44:00] |
PK - Posts: 12 |
Hi, I know them, but I look for a combination of DateTime String conversion, not separate into two functions, or how can we combine date and time into a datetime variable? Regards. |
[2019-06-12 03:14:43] |
You can just simply set the date and time individually into a new SCDateTime variable. Refer to: Working with the SCDateTime Variables and Values: SetDateTime() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
