Date/Time: Sun, 19 May 2024 14:30:30 +0000
cant find the Exact data point of High low of a bar
View Count: 579
[2019-06-10 00:57:02] |
Saurav.me - Posts: 3 |
How do i find the exact value of high low of a bar. I cant find even in "Chart value window". This is a very simple feautyre which is present everywhere, cant believe i have to use cross hair. Please let me know if there is an option to get the exact value. |
[2019-06-10 01:36:55] |
Yes you need to look at these values in the Tool Values Windows. Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 01:37:46
