Date/Time: Sat, 18 May 2024 11:02:07 +0000
Topstep connection
View Count: 615
[2019-06-04 12:35:32] |
AdrianB - Posts: 3 |
Rithmic Trading | Connected to data and trading server. | 2019-06-04 05:16:36.345 Rithmic Trading | Connection to non-affiliated broker not allowed. | 2019-06-04 05:16:36.345 * It appears that I can connect to Rithmic successfully on my platform, but I just get denied. My topstep account connects just fine on R|Trader Pro. What do I need to do to fix this? |
[2019-06-05 04:51:09] |
Make sure you are using your own direct Sierra Chart account to connect to Rithmic. This is the one that you have logged into this Support Board with. Refer to: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
