Date/Time: Sat, 18 May 2024 15:41:17 +0000
Dates not found while checking for invalid data in continuous contract data files.
View Count: 635
[2019-06-03 09:28:37] |
tesseract353 - Posts: 66 |
Any time the number of trades per bar is changed on symbol MES, the message log pops up with the logs provided below. This issue does not occur on other products. Please advise. MES.20190600.CME_Eq [CBV][M] 2000 Trades #8 | Reloading chart. | 2019-06-03 04:20:14.290 MES.20190600.CME_Eq [CBV][M] 2000 Trades #8 | Dates not found while checking for invalid data in continuous contract data files. MES.20190600.CME_Eq | 2019-06-03 04:20:14.300 * MES.20190600.CME_Eq [CBV][M] 2000 Trades #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-06-03 04:20:14.319 |
[2019-06-03 16:02:38] |
How many days of data is that chart set to load?
[2019-06-03 16:43:27] |
So far I have tried 1, 2, 3, 4, 5, 6, and 7 days. All of those settings cause the same issue to occur.
Date Time Of Last Edit: 2019-06-03 16:43:39
[2019-06-03 17:09:12] |
7 days should not be a problem. Follow the instructions here to fully re-download the data: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-03 17:09:29
[2019-06-04 13:35:31] |
After following the instructions, the issue remains.
[2019-06-04 17:19:11] |
What we recommend you do at this point is just set the Continuous Contract option in Chart >> Chart Settings >> Advanced Settings to None. We think the problem is because the starting date of this micro contract is later than when a June quarterly contract normally begins.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-04 17:19:16
[2019-06-04 17:33:57] |
That worked. Writing myself a note to change it back when the date-based rollover occurs. Thank you.
