Date/Time: Sun, 19 May 2024 00:04:04 +0000
The new version of SC cannot support Hong Kong CBBCs product
View Count: 913
[2019-05-27 06:58:07] |
User189399 - Posts: 43 |
I am using IB to trade HK CBBCs product with trading vendor IB. For example, 58404-IOPT-SEHK-HKD. It is a valid symbol for the SC version 1762 but become invalid for the most uptodate version. Pls advise how I change the symbol code for the new version of SC.
[2019-05-27 11:53:08] |
What does IOPT mean?
[2019-05-28 01:07:59] |
CBBCs product is the structure product of HK stock. IOPT is the security type shown in IB product description. It is similar with STK, OPT etc. Pls refer to the detail product description from IB with the link attached. https://drive.google.com/file/d/18OlKk3xVG2sq1uHT6p_BVcn909ti4TMn/view?usp=sharing |
2019-05-28_084746.png / V - Attached On 2019-05-28 00:49:29 UTC - Size: 21.77 KB - 236 views Attachment Deleted. |
[2019-05-28 09:27:48] |
In version 1925 support will be added for IOPT security types. But the format must follow what is documented here: Interactive Brokers Symbols: Options Format Sierra Chart must have standardized ways in which options are handled and this is going to be the only supported format. You must change the symbols to match when using this version or higher. There are no exceptions to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-28 15:35:38] |
Thank you for the support. Besides IOPT, I will also trade warrants with the security type WAR. Do the symbol format is simply to replace IOPT with WAR?
[2019-05-28 17:34:43] |
We need to add support for warrants as well. We will do that.
