Date/Time: Sun, 28 Apr 2024 05:07:11 +0000
With Shift Scrolls Vertical Scale problem/bug
View Count: 778
[2019-05-25 12:51:50] |
User343901 - Posts: 66 |
Hi support The following setting doesn't appear to be working: General Settings -> Scroll Wheel Scrolls Chart. With "Shift" Scrolls Vertical Scale Pressing shift has no effect when this setting is on. The other options all seem to work fine. Can you please have a look and confirm? Would be great to have this working. Thanks (reposted with fixed title) |
[2019-05-26 02:54:09] |
This is definitely functional in the latest prerelease. It might not be in the version you are running.
[2019-05-26 07:38:55] |
Yes, I was on 1919. Updated and all good now. Thank you
[2019-06-13 19:33:16] |
Mitote - Posts: 4 |
Hi, I have this problem too. The Shift and scroll wheel is not working. Strange thing is when I use a Apple Mouse the shift-scroll is working. I am on the latest version (1928) and use Parallels with Windows 10 Pro. I also tried the prerelease (1933) and also that version does not work Date Time Of Last Edit: 2019-06-13 19:37:52
[2019-06-14 17:25:53] |
And how do you have this option set: General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-15 07:50:35] |
Mitote - Posts: 4 |
Scroll Wheel Scrolls Chart. With "shift" Changes spacing. If I use the touch pad it also works. I tried two seperate USB connected mouses and only there the problem exist. Thanks for your help so far. |
[2019-06-15 13:51:57] |
If your scroll wheel does not perform any function according to that setting we do not see how we can help with this because the events are just not being received by Sierra Chart.
