Date/Time: Tue, 07 May 2024 18:15:09 +0000
DOM order information
View Count: 911
[2019-05-24 11:49:06] |
User495158 - Posts: 106 |
Hello! I have a problem with the sizing of DOM order information. If possible, I would like to see only order size, order type and queue position in the smallest format possible. Please see the attached screenshot. On the screenshot, DOM window 1 shows my default DOM window sizing with only basic order information enabled. If I decide to enable the queue position, a part of the information is hidden including the queue position (DOM window 2). To see the queue position, I have to resize DOM window, and not by little (DOM window 3). I suppose you can see that all this information just takes too much space and it makes a problem for traders who use more DOM windows. Possible solution would be maybe to add a separate column just for order info and to enable separate font size just for order information, or to reduce the amount of order information when the queue position is enabled (for example, to show L (for limit), Q (for queue):, Y (for order size), X (to modify or cancel order). I know that may not seem like an important issue but these small details are what makes a software truly outstanding, from a traders standpoint. Thanks Date Time Of Last Edit: 2019-05-24 11:51:01
[2019-05-24 13:22:03] |
seandunaway - Posts: 213 |
We've been hoping :D relevant: Estimated Position in Queue not showing in DOM |
[2019-07-03 15:49:40] |
We will see about adding different order line display options related to this.
