Date/Time: Sat, 18 May 2024 08:44:25 +0000
Chart Values / Crosshair
View Count: 1499
[2019-05-18 15:34:53] |
User38606 - Posts: 80 |
Hi, how do I switch on the information window that will show open high low close etc when I use Chart Value Tool to scroll through the chart. It is available on old version but I can't see it on new 1898 version of Sierra.
Capture11.PNG / V - Attached On 2019-05-18 15:34:32 UTC - Size: 4.26 KB - 304 views Attachment Deleted. |
[2019-05-18 17:40:01] |
The current version of Sierra Chart is 1919. To answer your question, refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
