Date/Time: Sat, 04 May 2024 02:03:40 +0000
Find symbols and sim trading.(remotly assistant help)
View Count: 561
[2019-05-16 16:55:53] |
Deniztemur - Posts: 1 |
Hi, i need som help with finding sp500. I wonder also if i can automaticly get my homework levels lined out on other charts autmaticly when i draw it on one of the charts? |
[2019-05-17 04:39:30] |
First, you are running an older version of Sierra Chart. Update to the current version: Software Download: Fast Update Do you want the S&P 500 cash index or futures? In regards to the other question, refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
