Date/Time: Mon, 29 Apr 2024 01:30:20 +0000
Right-clicking chart DOM
View Count: 882
[2019-05-16 02:27:09] |
User161560 - Posts: 17 |
Hi - When I right-click above the current bid Sierra will enter my order at market, which is great, but my attached OCO orders will be based off of the price at which I right-clicked rather then my entry price. I need my attached orders to be based on my entry price and not off the price I happen to right-click at. For example, if I right-click on the left of the chart DOM at 2849.00 and price is trading 2848.00 on the bid then Sierra will enter my order and I will usually get filled at 2848.25, which is what I want. However, if my attached OCO orders are a 2 point stop and a 2 point limit target my stop will be entered at 2847.00 and my limit target at 2851.00, based off the 2849.00 price I right-clicked at. I need the attached orders to be placed 2pts above and below my entry fill, so 2846.25 for the stop and 2850.25 for the limit target. Can you let me know how to do this please? Thanks Simon |
[2019-05-16 16:10:44] |
We see you are using Gain Capital. In that case you need to uncheck this option: Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) And make sure this option is checked: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) Or keep both of those options checked and then use this service which will give you exactly what you want along with server-side managed orders: Sierra Chart / Trading Technologies Futures Order Routing Service Could you tell us who your introducing broker is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-16 19:17:45] |
Thanks. My broker is Stage 5. What is the cost for Sierra Chart Order Routing Service with server-side managed orders? And can I keep my existing data feed if I use the Sierra Order Routing Service? Cheers, Simon Date Time Of Last Edit: 2019-05-16 19:49:11
[2019-05-17 15:02:16] |
At this point we recommend just waiting until we have a new service package which includes the data for this order routing service. And you would not want to keep the data feed you are using, you would want to use the Sierra Chart Exchange Data Feed. We are planning new service packages to include this data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
