Date/Time: Thu, 16 May 2024 15:55:25 +0000
Indicator values where crosshair is
View Count: 1010
[2019-04-30 08:14:53] |
User188188 - Posts: 7 |
Hei! How can I see indicator values where crosshair is? Let's say that I have some kind of oscillator, like stochastic, and I want to see the value of it 5 bars back. It usually shows the last bar value but when I move my crosshair 5 bars back (previous high) and want to see it's value I cannot see it because it plots the current value. Basically I want to see the indicator values where crosshair is. |
[2019-04-30 12:16:45] |
Refer to: Chart Drawing Tools: Chart Values/Crosshair Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-30 12:17:02
