Date/Time: Sat, 04 May 2024 12:41:23 +0000
get historical data from IB
View Count: 939
[2019-04-25 12:28:54] |
User479048 - Posts: 19 |
1) i want to know how sierra get historical data for a particular stock from IB i mean what time frame or date range it selects and on what basis. 2) can i define the time range and date and get historical data for a particular stock from IB. |
[2019-04-25 18:18:38] |
1. This is affected by this particular setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload And also this particular IB specific setting: Global Settings >> Data/Trade Service Settings >> Service Setting >>Maximum Historical Intraday Days To Download Limit All 24 hours of data is downloaded per day. 2. Other than the settings above the answer is no. If you want the data to come from Interactive Brokers make sure Sierra Chart is not using the Sierra Chart Historical Data: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-25 18:19:14
