Date/Time: Sun, 05 May 2024 01:00:29 +0000
Chart backround dragging
View Count: 767
[2019-04-23 19:44:06] |
Jccnacci0618 - Posts: 1 |
How do I get the cursor to move the chart back round ?
[2019-04-24 04:42:39] |
We assume you want to move the Chart data with the cursor. To do so you just have to have the Hand tool selected (Tools >> Hand). Refer to the documentation here: Chart Drawing Tools: Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
