Date/Time: Sun, 28 Apr 2024 14:58:57 +0000
15 days of FREE full usage time
View Count: 690
[2019-04-23 19:26:51] |
User214021 - Posts: 3 |
Hi, How can I use it ? Will I have the forex in real time? |
[2019-04-23 21:14:08] |
Sierra Chart - Max - Posts: 5597 |
The account is not restricted. We do not see a login on your trial. Refer to the Sierra Chart login instructions here: Sierra Chart - Software Login Instructions: Software Login Instructions Sierra Chart Support |
[2019-04-24 11:27:42] |
Hi Max, Thanks you for you answer. I added two Data / Trade Service Settings but it doesn't work. I have a poppu display me "This account requires activation ?" Do you have another data that can I use please ? |
[2019-04-29 20:45:59] |
We temporarily activated your account for a few days. You can use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service After the usage time ends, you need to make a payment: Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-29 20:46:35
