Date/Time: Fri, 03 May 2024 08:13:42 +0000
Scanning Multiple Pairs
View Count: 619
[2019-04-23 01:17:50] |
User798620 - Posts: 29 |
I have an alert i use to trade, at any given time i trade 20-40 different pairs. the problem is my computer really slows down when i have 40 pairs loaded. is there a way (i think there is just cant seem to find it) to have my alert active on all 40 pairs but only have a few open on my computer? if so would this fix the performance issue? or do i still need to get a better computer? thanks for all your help!
[2019-04-23 10:09:34] |
Well we are sure that you can improve performance. First refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often You can also hide any charts you do not need to look at through Window >> Hide Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
