Date/Time: Thu, 02 May 2024 09:16:46 +0000
Footprint Chart
View Count: 1087
[2019-04-22 23:48:40] |
Jeffrey S - Posts: 42 |
How do i change the color to identify the opening price on each new bar?
[2019-04-23 14:44:05] |
John - SC Support - Posts: 31293 |
For the Numbers Bars Study there are a few different options available to mark the Open and/or the Close for each bar. Refer to following for the Input to set the Open/Close Marker: Numbers Bars: Open and Close Marker Style Also be sure you look at the input immediately following for Place Open Marker/Boxes In, as this needs to be set to one of the Columns for the Numbers Bars in order to actually display the marker you select. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
