Date/Time: Thu, 02 May 2024 18:32:23 +0000
Version 1908 - Trade Activity
View Count: 696
[2019-04-20 16:26:52] |
KXRCap - Posts: 52 |
Dear SC - I was using v1894 all working good, noticed new versions moved up to v1908 and the only thing I see is not working is that In Trade Activity Log that it does not recognize the Commissions Component when calculating P/L. If I go back to 1894 all of my entered commissions are there in Symbol Settings, but not in the new version. I am really not interested in going thru 30 symbols and putting all the commissions back in. Please advise. Konrad. |
[2019-04-21 07:11:55] |
Marmany - Posts: 303 |
I have same issue with v1908 and confirm it is due to the fact that in Global Settings / Symbol Settings all my commission values were reset to zero after the update. Re-entering commission values in Symbol Settings corrected the Trade Activity Log. These values hold correctly after closing and re-opening Sierra. Agree with Konrad this is a chore. Please investigate and try to prevent recurrence on future updates. |
[2019-04-21 10:34:10] |
Refer to: Upcoming changes to Symbol Settings We will look into the problem. But this is going to be a one-time issue when we release the new symbol settings changes anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-21 10:42:49
