Date/Time: Thu, 02 May 2024 13:08:35 +0000
data upload
View Count: 578
[2019-04-17 11:36:23] |
User00111 - Posts: 111 |
I use a chartbook containing several ES / NQ / YM / RTY / EU / BUND / DAX week-daily tools (from 2000 to present) -240-60 (2018-01-01 to date) and I use 6 monitors The PC is an I7 6400 with 32 GB of Windws 10 ram I wanted to ask if it takes 30 minutes minimum? |
Monitor.png / V - Attached On 2019-04-17 11:34:53 UTC - Size: 512.84 KB - 218 views |
[2019-04-17 18:29:09] |
30 minutes for what exactly? The historical data downloading for the missing data should happen within 30 seconds. Something is very very wrong if it is taking 30 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 18:29:24
[2019-04-17 19:08:50] |
It may be that they are many graphs ? -- A. |
[2019-04-17 19:27:04] |
No, that should not be relevant. However, refer to help topic 30 for things to do to make sure Sierra Chart is not under too much of a load: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 19:28:21
