Date/Time: Sun, 05 May 2024 06:30:17 +0000
Last Trade Price Box
View Count: 934
[2019-04-17 08:20:29] |
ILIM KIRGIZ - Posts: 187 |
As I trade FX only last trade price is meaningless for me and occupying space in values scale. Is there a way to disable it? I tried changing the color of last trade price box under graphics settings by setting it to black but It still covers some underneath items I use via studies. Thanks. |
[2019-04-17 18:35:59] |
No, this is not supported.
[2019-04-24 05:51:32] |
Ok, how I can force it to go underneath of a study's value label which has been set to be shown at value scale?
[2019-04-24 18:29:12] |
We will add an option to disable the last trade price box. It will be out in the next release. Also you could always use one of the other options for the location of the Price Label instead of putting it in the Values Scale. Refer to Step 7 of the following for the options: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-25 06:15:39] |
TechTrader - Posts: 116 |
Re post #5 +1 |
