Date/Time: Fri, 03 May 2024 07:33:38 +0000
alert condition using custom study
View Count: 981
[2019-04-16 19:14:53] |
Glenn Infinity - Posts: 103 |
I do not know if this is possible, but wanted to make an audio alert or visual background alert when the Awesome oscillator changes color, (SG1), but since I can't find a way to define it is is possible?
[2019-04-17 03:17:29] |
You just have to base the formula on the condition which causes the color change. This is simply going to be a difference in values from one chart column to the next for the study. You can see the values through the Tool Values window: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 03:23:30
