Date/Time: Sun, 28 Apr 2024 17:06:26 +0000
Price on cursor
View Count: 1191
[2019-04-15 18:13:57] |
User531621 - Posts: 75 |
Hello, i just left Market Delta and i am use to the cursor displaying the price on candles, vwap, anywhere in the chart, etc etc. Does Sierra have that function?
[2019-04-15 18:24:00] |
Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-15 20:54:09] |
Great info however i dont see anywhere where it can customize a cursor displaying price. in other words, if i put my cursor at the bottom of a candle, it will show the low and high of that candle, in Market Delta. Do you have anything similar to that feature? Thank you
[2019-04-15 21:16:09] |
Yes that data is displayed in what is called the Tool Values window or Compact Tool Values Window both of which can be customized. You need to use the Chart Values tool for this: Chart Drawing Tools: Chart Values/Crosshair Also refer to: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 21:18:07
