Date/Time: Sat, 27 Apr 2024 14:21:11 +0000
Anyone have any suggestions?
View Count: 879
[2019-04-12 19:56:25] |
SierraFan - Posts: 84 |
Can you advise me on how I can create spread bar charts using different symbols. Examples are below. I've tried using difference bar,line, ratio with no luck. Maybe I'm not subscribed to the proper data. I haven't found a the correct way to display/set up the symbols in spread bar instead of line. The ohlc study overlay is so broken up. Should I use another chart platform for this specific task? I see it done in CQG .Thank You Ultra Bonds/Bund Bund/FBON Bund/FBTP DJI/Bond Nasd 100/Bond Russell/Bond Gold/Yuan Platinum/Gold DAX/BUND SPX/DAX YUAN/YEN |
[2019-04-15 11:06:50] |
The first question is are you getting proper charts for those particular symbols before calculating the spread. Are you you having a problem getting charts for those?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 11:07:09
[2019-04-16 00:51:13] |
Sierra, Thank You for not cussing me out. I tried again and used the ratio bar and everything worked properly on the list except for YUAN, FBON, FBTP. The entire list exactly matched bar for bar using continuation charts . Thank You for responding without using the word idiot. I could use a suggestion on the 3 that I could not find.
[2019-04-16 03:17:13] |
Sierra, disregard the question in post 3 . I finally found fbon and fbtp. Once again thank you for your patience with me.
[2019-04-16 15:10:32] |
User657944 - Posts: 173 |
SierraFan, is the BTP future available? I thought that FBTP was not supported by sierra.Thx
[2019-04-16 15:34:21] |
I'm able to pull up the chart IIM19 BTP Futures Long Term(FBTP)- Eurex This is off SC Data - All Services (data) |
[2019-04-17 03:20:30] |
This is definitely not true. All symbols are supported. This is contingent only on the particular Data or Trading service you are using. If Transact does not support this and you require this, then you need to use a different trading service. Have a look at:Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 03:20:48
