Date/Time: Mon, 29 Apr 2024 18:17:57 +0000
Chart Recalculation - Periodic study: consequential issue
View Count: 657
[2019-04-12 14:56:21] |
User13668 - Posts: 291 |
If while this study is applied to a chart, the user scrolls the chart back in time such that the green icon in the lower RH corner turns red. The chart will automatically return to the latest/most recent bar time when the Recalculation study performs it's stuff. This is a different behavior to using the Control + Insert keyboard shorcut or selecting Chart > Recalculate from the menu. In both these cases the chart remains at the point in history it was scrolled to. Is there a way to make the Study mimic the behavior of the menu and keyboard shortcut operation of recalculation? I do note that if the user has scrolled the chart back in time and the study is applied AND the user happens to be doing something on the chart (eg moving the mouse) at the time the study performs the recalculation then the chart stays scrolled UNTIL the user stops all activity at which point the chart will jump back to the latest/most recent bar time. |
[2019-04-12 16:27:41] |
This will be resolved in the next release. Not sure why we had set the chart to scroll to the end on a recalculate from a study and under other conditions. This may cause some unexpected consequence. Once we identify why that was needed we can then cause the chart to scroll to the end in that particular case.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-12 16:31:40
