Date/Time: Mon, 29 Apr 2024 14:15:02 +0000
Chart Header
View Count: 978
[2019-04-11 18:06:13] |
nicktrader - Posts: 665 |
In the bar chart the header information is displayed first and then the data of the studies. Unfortunately this differs for the TPO Chart. Is there a way to set the order in the TPO as in in the Bar Chart? |
Chart Header.png / V - Attached On 2019-04-11 18:05:56 UTC - Size: 11.49 KB - 286 views |
[2019-04-11 22:58:02] |
This depends upon the study display order. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-22 06:53:52] |
In the latest prerelease, this is solved where the header fields for the TPO Profile Chart is displayed always to the left.
