Date/Time: Mon, 06 May 2024 09:24:17 +0000
CQG Trade Log/Stats issues
View Count: 1000
[2019-04-09 20:11:12] |
Mike O - Posts: 5 |
I have a CQG / AMP Futures account. My trade log/history/stats does not update the daily profit and loss. Also, when I restart Sierra Chart while trades are open, and switch between Web and FIX API's, the floating P/L reported is incorrect by thousands of points. Is this expected behavior for the CQG integration? If I switch to using the "Sierra Chart Futures Order Routing Service" will that fix all the issues? Date Time Of Last Edit: 2019-04-09 20:58:51
[2019-04-10 18:56:55] |
In regards to the Daily Profit/Loss, refer to: Help With Daily Profit/Loss Value Update to the latest version to solve a problem with the CQG Position Average Price. The Sierra Chart futures order routing service does solve all trading statistics related issues. This is one of its features. This cannot be achieved with services like CQG and others. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-10 18:57:42
[2019-04-10 19:41:13] |
Mike O - Posts: 5 |
If I switch to the SCFORS will I have any way to monitor and manage trades from a mobile phone?
[2019-04-12 05:27:48] |
Not at this time. That will come later. But actually thinking about it, if TT has a web application for this, then yes. But there may be a monthly fee for that though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-12 05:28:33
