Date/Time: Thu, 14 May 2026 09:56:30 +0000
[User Discussion] - Histogram of Cumulative Delta
View Count: 5500
| [2013-11-20 20:02:35] |
| emp0804 - Posts: 31 |
Support, How can I display the Cumulative Delta candlesticks study into an histogram? Thanks |
| [2013-11-20 21:05:02] |
This is not supported.
| [2013-11-20 21:11:52] |
| Sawtooth - Posts: 4330 |
Use the Moving Average - Simple study, Set the Based On the CD study Set the Chart Region to 2 or higher Set the Input data to Close Set the Length to 1 Set the Draw Style to Bar Set the Auto-Coloring to Based on +/- This will work best if the CD study is set to Reset at Start of Trading Day. Date Time Of Last Edit: 2013-11-20 22:05:57
| [2018-11-28 11:21:23] |
| User829216 - Posts: 15 |
hello thx for the suggestion TomGilb. As it's 2018 I was wandering if a delta histogram study is available....pls see attached screen shot This is available in Ninja Trader Date Time Of Last Edit: 2018-11-30 09:42:18
| [2018-12-12 23:35:09] |
| lpfin123 - Posts: 59 |
I believe the study you are looking for is: Ask/Bid Volume Difference Bars. You can also add the text value with this study: Study Subgraph Above/Below Bar as Text. Hope this was what you were looking for. Cheers, |
| [2018-12-13 11:32:09] |
hey many thx for that - I stumbled across it a few days back and I should have updated this thread. It does the job well trade well |
| [2024-08-02 01:18:04] |
| User856649 - Posts: 10 |
Use the Moving Average - Simple study, Set the Based On the CD study Set the Chart Region to 2 or higher Set the Input data to Close Set the Length to 1 Set the Draw Style to Bar Set the Auto-Coloring to Based on +/- |
