Date/Time: Mon, 06 May 2024 19:39:42 +0000
Download historical data for back-testing
View Count: 1069
[2019-04-09 13:22:31] |
User266447 - Posts: 244 |
Hello, I would like to download a tick data and a volume data from DAX and BUND and use it for a back-testing. Could you guide me on how can I do it, please? Kind regards, Arek |
[2019-04-09 18:26:00] |
Use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-10 10:49:44] |
Hello, Can I download a volume data? - for DAX and Bund? Kind regards, Arek |
[2019-04-10 18:34:02] |
Yes the volume data is included. There is nothing special to do.
[2019-04-18 09:30:26] |
Hello, I would like to download tick data. Which chart shall I use it? OHLC chart or a candlestick chart? I need a tick data second by second so I know I can convert the data into...a Renko bar or Range bar - and so on. I am not sure which chart I can take the tick historical data from? Before when I wanted to download historical data from the Point and Figure chart then I opened the P&F chart and downloaded the historical data from the chart. Now I am looking to download a tick data from the 1-second chart - but I am not sure which chart to put on? OHLC or a different one? Please advice. Kind regards, Arek |
[2019-04-18 17:57:18] |
Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
