Date/Time: Tue, 07 May 2024 02:26:43 +0000
Intraday chart looks completely different to other platform such as tradingview
View Count: 1363
[2019-04-07 01:10:02] |
ruiyt - Posts: 11 |
I noticed that the intraday chart is vastly different from tradingview for futures contract. I've tried to change timezone and session settings, but no matter what I do the chart still looks completely different from tradingview. I'm completely lost as what to do. Please advise. Thanks. Screenshots of both tradingview and sierra chart are provided below. http://www.sierrachart.com/image.php?Image=1554598338569.png Date Time Of Last Edit: 2019-04-07 02:10:44
tradingview.PNG / V - Attached On 2019-04-07 00:53:59 UTC - Size: 108.56 KB - 317 views |
[2019-04-09 04:33:09] |
Most likely this is because of different Bar Starting Times: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-09 04:33:40
[2020-02-01 18:09:51] |
User791909 - Posts: 7 |
If the op is still looking for the settings to make Sierra Chart candles look like TradingView candles for a futures chart, I believe the bar starting times you need for Eastern time zone are: Day start time 18:00:00 Day end time 16:59:59 Just leave “use evening session” deselected/inactive as the above times cover the full tradable hours for CME futures like ES. Adjust for your own time zone. That should produce the candles you seek on a futures chart. |
