Date/Time: Sat, 04 May 2024 04:54:39 +0000
Using both percentage and minimum Volume diagonal threshold in Volume at Price v2
View Count: 1097
[2019-03-26 06:48:31] |
jawtrader - Posts: 10 |
In reading the documentation, I don't think I'm able to do both a minimum volume threshold and ratio for diagonal comparison in the Volume at Price v2 study. The idea is to use a minimum diagonal ratio such as 400% and a diagonal difference also of at least 200. If not possible in the study, do you have a recommendation how to combine this otherwise into a single alert? |
[2019-04-23 11:22:24] |
User873570 - Posts: 27 |
I've been asking for this as well. A few Numbers Bars requests - market imbalance projection lines |
[2019-04-24 00:39:02] |
We will see about adding this.
