Date/Time: Tue, 21 May 2024 14:56:11 +0000
Inquiry about export of intra day tick data
View Count: 777
[2019-03-25 15:29:33] |
User14410 - Posts: 38 |
I tried to export the intra day tick data for ESM19 but the earliest date for the txt file is 20th Feb, 2019. May I ask is it not possible for me to export more intra day tick data dated before 20th Feb, 2019 if I originally set the configuration as that in the attached photo? Also, could I export in a continuous futures format instead of for different symbols of futures contract? Thank you very much. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=27042 |
[2019-03-25 18:59:49] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data And because you are exporting tick by tick data it is best that you just do this symbol by symbol rather than using a continuous futures contract chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-19 01:16:06] |
Thank you. So if I set the "use number of days to load" to 1, and try to export tick by tick data for each symbol, then Sierra chart will automatically create tick by tick data in txt file format for each day?
[2019-07-21 20:21:02] |
John - SC Support - Posts: 31765 |
This has been answered in this thread: Inquiry about exporting tick data into seperate txt files according to date
