Date/Time: Thu, 05 Nov 2026 21:06:53 +0000
Sierra studies not working
View Count: 1754
[2019-03-14 11:44:44]
User491464 - Posts: 21
A couple of my Sierra chart studies are not working anymore.
I am getting the following error message;
sierrachartstudies.dll is missing. May have been removed by anti-malware software. To recover download current version
Is there any fix without having to download the current version?
[2019-03-14 15:19:56]
You can always redownload the same version you are running. To do this follow the instructions here:
Software Download: Software Rollback Procedure
Although we always recommend updating to the most current version in order to keep everything up to date.
Also, you will need to create an exception for that file in your Anti-Virus software so that the file is not removed again.
[2019-03-15 19:31:09]
Thanks for the response.
I am trying to stay on version 1865 but when I try to reinstall this version I am getting the error message; error saving downloaded files to local system. I have sent the log to support (my email **).
I don't know if it's of relevance; but the issue that I am trying to rectify relating to the missing sierrachartstudies.dll is only occurring in a sub instance, using the data feed of the main instance. The main instance is working is normal.
Thanks for your help
Date Time Of Last Edit: 2019-03-15 21:54:13
[2019-03-15 20:34:37]
Log:
Installer version: 9
Not using HTTP proxy server settings.
HTTP Request: https://www.sierrachart.com/downloads/1865/FilesToDownload.txt
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203.
Not overwriting file since it exists: EURUSD.dly
HTTP Request: https://www.sierrachart.com/downloads/Common1821/FilesToDownload.txt
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 46.4.97.203.
Starting request of files to install.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILCustomChartBars.h
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILCustomChartBars_Example.cpp
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILDepthBars.h
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILSpreadsheetInteraction.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/AutomatedTradeManagementBySubgraph.cpp
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CandleStickPatternNames.cpp
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CandleStickPatternNames.h
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CustomChart.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ExampleCustomStudies.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/GDIExample.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/IntradayRecord.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/OrderEntryStudies.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/RequestValuesFromServerAndDraw.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCString.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCStudyFunctions.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCStudyFunctions.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCSymbolData.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SpreadOrderEntry.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies2.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies3.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies4.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies5.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies6.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies7.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies8.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Systems.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Template.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TickIndex.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingSystem.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingSystemBasedOnAlertCondition.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingTriggeredLimitOrderEntry.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/VAPContainer.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/sccolors.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scconstants.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scdatetime.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scstructures.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/sierrachart.h
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.h
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.proto
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocolVLS.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocolVLS.h
HTTP request: https://www.sierrachart.com/downloads/1865/Data/2TargetsWithBEStop.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/2TargetsWithCommonStop.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/ChartbookExample.cht
HTTP request: https://www.sierrachart.com/downloads/1865/Data/Clean Chart.stdycollct
HTTP request: https://www.sierrachart.com/downloads/1865/Data/SimpleBracket.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/UserContributedStudies.dll
HTTP request: https://www.sierrachart.com/downloads/1865/Data/UserContributedStudies_64.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChart.exe
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChartStudies.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChartStudies_64.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChart_64.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/3beeps.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/AlertSound.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/AlertSound2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/Cash Reg.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/High beep1.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenCanceled.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenFilled.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenModified.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/airplane.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/applause.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/blong2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/buzzer2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/honk.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/pager.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/police-siren.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_10.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_14.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_15.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_157.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_16.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_161.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_163.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_17.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_175.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_23.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_247.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_26.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_267.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_27.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_28.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_29.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_299.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_3.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_30.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_300.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_301.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_302.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_303.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_304.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_305.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_306.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_307.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_308.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_309.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_31.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_312.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_317.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_318.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_319.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_32.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_320.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_322.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_323.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_324.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_325.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_326.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_327.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_328.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_329.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_33.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_34.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_340.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_35.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_36.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_37.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_39.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_40.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_41.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_43.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_56.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_599.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_66.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_69.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_70.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_72.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_73.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_74.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_75.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_76.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_766.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_84.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_85.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_89.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_9.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_90.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_92.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_93.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_94.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_95.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_96.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/SciLexer.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/contextMenu.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/doLocalConf.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/functionList.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/langs.model.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/langs.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/license.txt
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/localization/english.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/localization/english_customizable.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/notepad .exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/APIs/batch.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/APIs/cpp.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/mimeTools.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/readme.txt
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/shortcuts.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/stylers.model.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/stylers.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/DTCBridge.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_cert_auth_params
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_client_params
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_client_private_key
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashRpt1403.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashRptProbe1403.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashSender1403.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/RIJNDAEL.DLL
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAOrderServerAPI.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAPriceEngineAPI.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAWireTypesCPP.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TransactToSierraBridge.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/aesc.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/crashrpt_lang.ini
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/xerces-c_3_1.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/zlib1.dll
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed.
Received file: ACSILCustomChartBars.h
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILCustomChartBars.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILCustomChartBars_Example.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILCustomChartBars_Example.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILDepthBars.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILDepthBars.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILSpreadsheetInteraction.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILSpreadsheetInteraction.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Creating socket. Using TLS 1.2.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Connecting to IP: 46.4.97.203.
Received file: AutomatedTradeManagementBySubgraph.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\AutomatedTradeManagementBySubgraph.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Closed.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Closed.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Closed.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Closed.
Received file: CustomChart.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CustomChart.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: CandleStickPatternNames.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CandleStickPatternNames.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: CandleStickPatternNames.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CandleStickPatternNames.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: ExampleCustomStudies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ExampleCustomStudies.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Closed.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (9) | Creating socket. Using TLS 1.2.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (9) | Connecting to IP: 46.4.97.203.
Received file: GDIExample.cpp
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Socket gracefully closed by remote side.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\GDIExample.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (5) | Closed.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Closed.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Closed.
Received file: IntradayRecord.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\IntradayRecord.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: SCString.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCString.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: RequestValuesFromServerAndDraw.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\RequestValuesFromServerAndDraw.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderEntryStudies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\OrderEntryStudies.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Closed.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (9) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (8) | Creating socket. Using TLS 1.2.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (8) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (9) | Socket gracefully closed by remote side.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (9) | Closed.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Closed.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Closed.
Received file: SCStudyFunctions.cpp
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (6) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCStudyFunctions.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: SCSymbolData.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCSymbolData.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: SCStudyFunctions.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCStudyFunctions.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: SpreadOrderEntry.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SpreadOrderEntry.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Closed.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (5) | Closed.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Closed.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (7) | Closed.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (8) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Connecting to IP: 46.4.97.203.
Received file: Studies2.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies2.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (8) | Socket gracefully closed by remote side.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (8) | Closed.
Received file: Studies3.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies3.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies4.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies4.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies5.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies5.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies6.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies6.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Closed.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Closed.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (4) | Closed.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (3) | Closed.
Received file: Studies7.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies7.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Closed.
Received file: Systems.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Systems.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies8.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies8.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Template.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Template.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: TickIndex.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TickIndex.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Closed.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (7) | Closed.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Closed.
Received file: TradingSystem.cpp
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (2) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingSystem.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Connecting to IP: 46.4.97.203.
Received file: TradingSystemBasedOnAlertCondition.cpp
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingSystemBasedOnAlertCondition.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: TradingTriggeredLimitOrderEntry.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingTriggeredLimitOrderEntry.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: VAPContainer.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\VAPContainer.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: sccolors.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\sccolors.h. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Closed.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Closed.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Closed.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (7) | Closed.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (6) | Connecting to IP: 46.4.97.203.
Received file: scdatetime.h
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scdatetime.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: scconstants.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scconstants.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: scstructures.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scstructures.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: sierrachart.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\sierrachart.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocol.cpp
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (2) | Closed.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (3) | Closed.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (4) | Closed.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (3) | Connecting to IP: 46.4.97.203.
Received file: DTCProtocol.proto
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (5) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.proto. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocol.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.h. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (4) | Connecting to IP: 46.4.97.203.
Received file: DTCProtocolVLS.cpp
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (6) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocolVLS.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocolVLS.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocolVLS.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: 2TargetsWithBEStop.twconfig
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\2TargetsWithBEStop.twconfig. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (7) | Closed.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Closed.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (2) | Closed.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Connecting to IP: 46.4.97.203.
Received file: 2TargetsWithCommonStop.twconfig
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\2TargetsWithCommonStop.twconfig. Error: Windows error code 3: The system cannot find the path specified.
Received file: ChartbookExample.cht
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\ChartbookExample.cht. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (3) | Closed.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (4) | Closed.
Received file: Clean Chart.stdycollct
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\Clean Chart.stdycollct. Error: Windows error code 3: The system cannot find the path specified.
Received file: SimpleBracket.twconfig
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\SimpleBracket.twconfig. Error: Windows error code 3: The system cannot find the path specified.
Received file: UserContributedStudies.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\UserContributedStudies.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (6) | Closed.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (5) | Closed.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (1) | Closed.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Closed.
Received file: UserContributedStudies_64.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\UserContributedStudies_64.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Closed.
Received file: SierraChartStudies.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChartStudies.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: SierraChartStudies_64.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChartStudies_64.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Closed.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (5) | Closed.
Received file: 3beeps.wav
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\3beeps.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (1) | Closed.
Received file: AlertSound2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\AlertSound2.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: AlertSound.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\AlertSound.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Closed.
Received file: SierraChart.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChart.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: Cash Reg.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\Cash Reg.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (5) | Closed.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Closed.
Received file: High beep1.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\High beep1.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderHasBeenCanceled.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenCanceled.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (7) | Closed.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (1) | Closed.
Received file: OrderHasBeenFilled.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenFilled.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Closed.
Received file: SierraChart_64.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChart_64.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderHasBeenModified.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenModified.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (6) | Closed.
Received file: airplane.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\airplane.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: applause.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\applause.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (4) | Closed.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (5) | Closed.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Closed.
Received file: blong2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\blong2.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: buzzer2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\buzzer2.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: honk.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\honk.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (1) | Closed.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (3) | Closed.
Received file: pager.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\pager.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: police-siren.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\police-siren.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (6) | Closed.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (4) | Closed.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (4) | Connecting to IP: 46.4.97.203.
Received file: Button_10.bmp
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_10.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Closed.
Received file: Button_14.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_14.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (6) | Connecting to IP: 46.4.97.203.
Received file: Button_15.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_15.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Closed.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (1) | Closed.
Received file: Button_157.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_157.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_16.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_16.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (3) | Closed.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (3) | Connecting to IP: 46.4.97.203.
Received file: Button_161.bmp
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (4) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_161.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (5) | Closed.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (4) | Connecting to IP: 46.4.97.203.
Received file: Button_163.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_163.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_17.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_17.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (6) | Closed.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Closed.
Received file: Button_175.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_175.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_23.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_23.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (1) | Closed.
Received file: Button_247.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_247.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (3) | Closed.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (2) | Closed.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (3) | Connecting to IP: 46.4.97.203.
Received file: Button_26.bmp
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (4) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_26.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_267.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_267.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (5) | Closed.
Received file: Button_28.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_28.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_27.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_27.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (6) | Closed.
Received file: Button_29.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_29.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (1) | Closed.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Closed.
Received file: Button_299.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_299.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (1) | Connecting to IP: 46.4.97.203.
Received file: Button_3.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_3.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (3) | Closed.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (2) | Closed.
Received file: Button_30.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_30.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_300.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_300.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (4) | Closed.
Received file: Button_301.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_301.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (5) | Closed.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (6) | Closed.
Received file: Button_302.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_302.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (5) | Connecting to IP: 46.4.97.203.
Received file: Button_303.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_303.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (1) | Closed.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Closed.
Received file: Button_304.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_304.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_305.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_305.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (2) | Closed.
Received file: Button_306.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_306.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Closed.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (4) | Closed.
Received file: Button_307.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_307.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (3) | Connecting to IP: 46.4.97.203.
Received file: Button_308.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_308.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (5) | Closed.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (1) | Closed.
Received file: Button_309.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_309.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (1) | Connecting to IP: 46.4.97.203.
Received file: Button_31.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_31.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Closed.
Received file: Button_312.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_312.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (2) | Closed.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (7) | Closed.
Received file: Button_317.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_317.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (6) | Connecting to IP: 46.4.97.203.
Received file: Button_318.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_318.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (3) | Closed.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (4) | Closed.
Received file: Button_319.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_319.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_32.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_32.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (1) | Closed.
Received file: Button_320.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_320.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (2) | Closed.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Closed.
Received file: Button_323.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_323.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_322.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_322.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (6) | Closed.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (3) | Closed.
Received file: Button_324.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_324.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Connecting to IP: 46.4.97.203.
Received file: Button_325.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_325.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (4) | Closed.
Received file: Button_326.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_326.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (7) | Closed.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (1) | Closed.
Received file: Button_327.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_327.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_328.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_328.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (2) | Closed.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (5) | Closed.
Received file: Button_329.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_329.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (2) | Connecting to IP: 46.4.97.203.
Received file: Button_33.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_33.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Closed.
Received file: Button_34.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_34.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (4) | Closed.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (6) | Closed.
Received file: Button_340.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_340.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_35.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_35.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (7) | Closed.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (1) | Closed.
Received file: Button_36.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_36.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_37.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_37.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (2) | Closed.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (2) | Connecting to IP: 46.4.97.203.
Received file: Button_39.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_39.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Closed.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (4) | Closed.
Received file: Button_40.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_40.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_41.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_41.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (6) | Closed.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (5) | Closed.
Received file: Button_56.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_56.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_43.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_43.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (1) | Closed.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (1) | Connecting to IP: 46.4.97.203.
Received file: Button_599.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_599.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (2) | Closed.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Closed.
Received file: Button_66.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_66.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_69.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_69.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (4) | Closed.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (7) | Closed.
Received file: Button_70.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_70.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_72.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_72.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (5) | Closed.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (7) | Connecting to IP: 46.4.97.203.
Received file: Button_73.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_73.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (6) | Closed.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (1) | Closed.
Received file: Button_74.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_74.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_75.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_75.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Closed.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (2) | Closed.
Received file: Button_76.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_76.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_766.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_766.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (4) | Closed.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (4) | Connecting to IP: 46.4.97.203.
Received file: Button_84.bmp
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (5) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_84.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (7) | Closed.
Received file: Button_89.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_89.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_85.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_85.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (1) | Closed.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Closed.
Received file: Button_9.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_9.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_90.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_90.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (2) | Closed.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (4) | Closed.
Received file: Button_92.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_92.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (3) | Closed.
Received file: Button_93.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_93.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_94.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_94.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Closed.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Closed.
Received file: Button_95.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_95.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_96.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_96.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (1) | Closed.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (2) | Closed.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (6) | Closed.
Received file: contextMenu.xml
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\contextMenu.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: doLocalConf.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\doLocalConf.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (3) | Closed.
Received file: SciLexer.dll
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (4) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\SciLexer.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: functionList.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\functionList.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: langs.model.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\langs.model.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (7) | Closed.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (1) | Closed.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Closed.
Received file: license.txt
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\license.txt. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Connecting to IP: 46.4.97.203.
Received file: langs.xml
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (2) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\langs.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: english.xml
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\english.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (6) | Closed.
Received file: english_customizable.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\english_customizable.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (4) | Closed.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (3) | Closed.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (3) | Connecting to IP: 46.4.97.203.
Received file: batch.xml
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (1) | Closed.
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\batch.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: notepad .exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\notepad .exe. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (1) | Connecting to IP: 46.4.97.203.
Received file: cpp.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\cpp.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Closed.
Received file: mimeTools.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\mimeTools.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: readme.txt
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\readme.txt. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (6) | Closed.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (4) | Closed.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (2) | Closed.
Received file: shortcuts.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\shortcuts.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (4) | Connecting to IP: 46.4.97.203.
Received file: stylers.xml
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (3) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\stylers.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: stylers.model.xml
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (1) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\stylers.model.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: rim_ssl_cert_auth_params
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_cert_auth_params. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (5) | Closed.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (6) | Closed.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (7) | Closed.
Received file: rim_ssl_client_params
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_client_params. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (4) | Closed.
Received file: rim_ssl_client_private_key
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_client_private_key. Error: Windows error code 3: The system cannot find the path specified.
Received file: CrashRpt1403.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashRpt1403.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCBridge.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\DTCBridge.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: CrashRptProbe1403.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashRptProbe1403.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (1) | Closed.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (3) | Closed.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (5) | Closed.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (2) | Closed.
Received file: RIJNDAEL.DLL
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\RIJNDAEL.DLL. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (6) | Closed.
Received file: CrashSender1403.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashSender1403.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: TAOrderServerAPI.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAOrderServerAPI.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: TAPriceEngineAPI.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAPriceEngineAPI.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: TAWireTypesCPP.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAWireTypesCPP.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (1) | Closed.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (4) | Closed.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (5) | Closed.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (3) | Closed.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (3) | Connecting to IP: 46.4.97.203.
Received file: TransactToSierraBridge.exe
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (2) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TransactToSierraBridge.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: aesc.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\aesc.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: crashrpt_lang.ini
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\crashrpt_lang.ini. Error: Windows error code 3: The system cannot find the path specified.
Received file: zlib1.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\zlib1.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: xerces-c_3_1.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\xerces-c_3_1.dll. Error: Windows error code 3: The system cannot find the path specified.
Error saving downloaded files to local system. Stopping installation. Check log.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (6) | Closed.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (1) | Closed.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (4) | Closed.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (3) | Closed.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Closed.
Not using HTTP proxy server settings.
HTTP Request: https://www.sierrachart.com/downloads/1865/FilesToDownload.txt
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203.
Not overwriting file since it exists: EURUSD.dly
HTTP Request: https://www.sierrachart.com/downloads/Common1821/FilesToDownload.txt
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 46.4.97.203.
Starting request of files to install.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILCustomChartBars.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILCustomChartBars_Example.cpp
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILDepthBars.h
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ACSILSpreadsheetInteraction.cpp
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/AutomatedTradeManagementBySubgraph.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CandleStickPatternNames.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CandleStickPatternNames.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/CustomChart.cpp
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/ExampleCustomStudies.cpp
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Creating socket. Using TLS 1.2.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/GDIExample.cpp
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Connecting to IP: 46.4.97.203.
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/IntradayRecord.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/OrderEntryStudies.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/RequestValuesFromServerAndDraw.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCString.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCStudyFunctions.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCStudyFunctions.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SCSymbolData.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/SpreadOrderEntry.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies2.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies3.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies4.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies5.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies6.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies7.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Studies8.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Systems.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/Template.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TickIndex.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingSystem.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingSystemBasedOnAlertCondition.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/TradingTriggeredLimitOrderEntry.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/VAPContainer.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/sccolors.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scconstants.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scdatetime.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/scstructures.h
HTTP request: https://www.sierrachart.com/downloads/1865/ACS_Source/sierrachart.h
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.h
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocol.proto
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocolVLS.cpp
HTTP request: https://www.sierrachart.com/downloads/1865/DTC/DTCProtocolVLS.h
HTTP request: https://www.sierrachart.com/downloads/1865/Data/2TargetsWithBEStop.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/2TargetsWithCommonStop.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/ChartbookExample.cht
HTTP request: https://www.sierrachart.com/downloads/1865/Data/Clean Chart.stdycollct
HTTP request: https://www.sierrachart.com/downloads/1865/Data/SimpleBracket.twconfig
HTTP request: https://www.sierrachart.com/downloads/1865/Data/UserContributedStudies.dll
HTTP request: https://www.sierrachart.com/downloads/1865/Data/UserContributedStudies_64.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChart.exe
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChartStudies.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChartStudies_64.dll
HTTP request: https://www.sierrachart.com/downloads/1865/SierraChart_64.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/3beeps.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/AlertSound.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/AlertSound2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/Cash Reg.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/High beep1.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenCanceled.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenFilled.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/OrderHasBeenModified.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/airplane.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/applause.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/blong2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/buzzer2.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/honk.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/pager.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/AlertSounds/police-siren.wav
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_10.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_14.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_15.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_157.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_16.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_161.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_163.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_17.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_175.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_23.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_247.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_26.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_267.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_27.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_28.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_29.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_299.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_3.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_30.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_300.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_301.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_302.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_303.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_304.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_305.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_306.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_307.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_308.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_309.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_31.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_312.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_317.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_318.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_319.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_32.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_320.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_322.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_323.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_324.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_325.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_326.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_327.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_328.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_329.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_33.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_34.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_340.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_35.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_36.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_37.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_39.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_40.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_41.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_43.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_56.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_599.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_66.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_69.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_70.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_72.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_73.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_74.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_75.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_76.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_766.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_84.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_85.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_89.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_9.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_90.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_92.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_93.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_94.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_95.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/Graphics/Buttons/Button_96.bmp
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/SciLexer.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/contextMenu.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/doLocalConf.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/functionList.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/langs.model.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/langs.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/license.txt
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/localization/english.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/localization/english_customizable.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/notepad .exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/APIs/batch.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/APIs/cpp.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/plugins/mimeTools.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/readme.txt
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/shortcuts.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/stylers.model.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/NPP/stylers.xml
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/DTCBridge.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_cert_auth_params
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_client_params
HTTP request: https://www.sierrachart.com/downloads/Common1821/Rim/rim_ssl_client_private_key
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashRpt1403.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashRptProbe1403.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/CrashSender1403.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/RIJNDAEL.DLL
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAOrderServerAPI.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAPriceEngineAPI.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TAWireTypesCPP.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/TransactToSierraBridge.exe
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/aesc.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/crashrpt_lang.ini
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/xerces-c_3_1.dll
HTTP request: https://www.sierrachart.com/downloads/Common1821/Transact/zlib1.dll
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed.
Received file: ACSILDepthBars.h
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILDepthBars.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILCustomChartBars.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILCustomChartBars.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILCustomChartBars_Example.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILCustomChartBars_Example.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: ACSILSpreadsheetInteraction.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ACSILSpreadsheetInteraction.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Connecting to IP: 46.4.97.203.
Received file: AutomatedTradeManagementBySubgraph.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\AutomatedTradeManagementBySubgraph.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Creating socket. Using TLS 1.2.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (9) | Creating socket. Using TLS 1.2.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (9) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (3) | Closed.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (5) | Closed.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:6 to www.sierrachart.com:443 for request ID:6 (6) | Closed.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (4) | Closed.
Received file: CandleStickPatternNames.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CandleStickPatternNames.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: CandleStickPatternNames.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CandleStickPatternNames.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: CustomChart.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\CustomChart.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: ExampleCustomStudies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\ExampleCustomStudies.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:7 to www.sierrachart.com:443 for request ID:7 (1) | Closed.
Received file: GDIExample.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\GDIExample.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (9) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:9 to www.sierrachart.com:443 for request ID:9 (7) | Closed.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:8 to www.sierrachart.com:443 for request ID:8 (2) | Closed.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (9) | Socket gracefully closed by remote side.
HTTPS connection ID:11 to www.sierrachart.com:443 for request ID:11 (9) | Closed.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Socket gracefully closed by remote side.
HTTPS connection ID:10 to www.sierrachart.com:443 for request ID:10 (8) | Closed.
Received file: IntradayRecord.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\IntradayRecord.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderEntryStudies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\OrderEntryStudies.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: SCString.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCString.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: RequestValuesFromServerAndDraw.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\RequestValuesFromServerAndDraw.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:12 to www.sierrachart.com:443 for request ID:12 (3) | Closed.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (8) | Creating socket. Using TLS 1.2.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (8) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (9) | Creating socket. Using TLS 1.2.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (9) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:13 to www.sierrachart.com:443 for request ID:13 (1) | Closed.
Received file: SCStudyFunctions.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCStudyFunctions.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:15 to www.sierrachart.com:443 for request ID:15 (5) | Closed.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:16 to www.sierrachart.com:443 for request ID:16 (6) | Closed.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:14 to www.sierrachart.com:443 for request ID:14 (4) | Closed.
Received file: SCStudyFunctions.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCStudyFunctions.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: SpreadOrderEntry.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SpreadOrderEntry.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: SCSymbolData.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\SCSymbolData.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:17 to www.sierrachart.com:443 for request ID:17 (2) | Closed.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:18 to www.sierrachart.com:443 for request ID:18 (3) | Closed.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (8) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:19 to www.sierrachart.com:443 for request ID:19 (7) | Closed.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (8) | Socket gracefully closed by remote side.
HTTPS connection ID:20 to www.sierrachart.com:443 for request ID:20 (8) | Closed.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (9) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Connecting to IP: 46.4.97.203.
Received file: Studies2.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies2.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (9) | Socket gracefully closed by remote side.
HTTPS connection ID:21 to www.sierrachart.com:443 for request ID:21 (9) | Closed.
Received file: Studies3.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies3.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies5.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies5.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies4.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies4.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies6.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies6.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:22 to www.sierrachart.com:443 for request ID:22 (1) | Closed.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:23 to www.sierrachart.com:443 for request ID:23 (2) | Closed.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:25 to www.sierrachart.com:443 for request ID:25 (4) | Closed.
Received file: Studies7.cpp
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:24 to www.sierrachart.com:443 for request ID:24 (3) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies7.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:26 to www.sierrachart.com:443 for request ID:26 (5) | Closed.
Received file: Systems.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Systems.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Studies8.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Studies8.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Template.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\Template.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: TickIndex.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TickIndex.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:27 to www.sierrachart.com:443 for request ID:27 (6) | Closed.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:29 to www.sierrachart.com:443 for request ID:29 (2) | Closed.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:28 to www.sierrachart.com:443 for request ID:28 (1) | Closed.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Connecting to IP: 46.4.97.203.
Received file: TradingSystem.cpp
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:30 to www.sierrachart.com:443 for request ID:30 (7) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingSystem.cpp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:31 to www.sierrachart.com:443 for request ID:31 (3) | Closed.
Received file: TradingSystemBasedOnAlertCondition.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingSystemBasedOnAlertCondition.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: TradingTriggeredLimitOrderEntry.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\TradingTriggeredLimitOrderEntry.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: VAPContainer.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\VAPContainer.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: sccolors.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\sccolors.h. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:32 to www.sierrachart.com:443 for request ID:32 (4) | Closed.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:33 to www.sierrachart.com:443 for request ID:33 (5) | Closed.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (8) | Creating socket. Using TLS 1.2.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (8) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:34 to www.sierrachart.com:443 for request ID:34 (6) | Closed.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:36 to www.sierrachart.com:443 for request ID:36 (1) | Closed.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:35 to www.sierrachart.com:443 for request ID:35 (2) | Closed.
Received file: scconstants.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scconstants.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: scdatetime.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scdatetime.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: scstructures.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\scstructures.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocol.cpp
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: sierrachart.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\ACS_Source\sierrachart.h. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:37 to www.sierrachart.com:443 for request ID:37 (3) | Closed.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:38 to www.sierrachart.com:443 for request ID:38 (4) | Closed.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:39 to www.sierrachart.com:443 for request ID:39 (5) | Closed.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (8) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (5) | Connecting to IP: 46.4.97.203.
Received file: DTCProtocol.h
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:40 to www.sierrachart.com:443 for request ID:40 (7) | Closed.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (8) | Socket gracefully closed by remote side.
HTTPS connection ID:41 to www.sierrachart.com:443 for request ID:41 (8) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.h. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocol.proto
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocol.proto. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocolVLS.cpp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocolVLS.cpp. Error: Windows error code 3: The system cannot find the path specified.
Received file: 2TargetsWithBEStop.twconfig
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\2TargetsWithBEStop.twconfig. Error: Windows error code 3: The system cannot find the path specified.
Received file: DTCProtocolVLS.h
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\DTC\DTCProtocolVLS.h. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:42 to www.sierrachart.com:443 for request ID:42 (1) | Closed.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:43 to www.sierrachart.com:443 for request ID:43 (2) | Closed.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:44 to www.sierrachart.com:443 for request ID:44 (3) | Closed.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Connecting to IP: 46.4.97.203.
Received file: 2TargetsWithCommonStop.twconfig
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:46 to www.sierrachart.com:443 for request ID:46 (5) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\2TargetsWithCommonStop.twconfig. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Connecting to IP: 46.4.97.203.
Received file: ChartbookExample.cht
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\ChartbookExample.cht. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:45 to www.sierrachart.com:443 for request ID:45 (4) | Closed.
Received file: Clean Chart.stdycollct
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\Clean Chart.stdycollct. Error: Windows error code 3: The system cannot find the path specified.
Received file: SimpleBracket.twconfig
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\SimpleBracket.twconfig. Error: Windows error code 3: The system cannot find the path specified.
Received file: UserContributedStudies.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\UserContributedStudies.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:47 to www.sierrachart.com:443 for request ID:47 (6) | Closed.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:48 to www.sierrachart.com:443 for request ID:48 (1) | Closed.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:49 to www.sierrachart.com:443 for request ID:49 (7) | Closed.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:50 to www.sierrachart.com:443 for request ID:50 (2) | Closed.
Received file: UserContributedStudies_64.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Data\UserContributedStudies_64.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:51 to www.sierrachart.com:443 for request ID:51 (3) | Closed.
Received file: SierraChartStudies.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChartStudies.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: SierraChartStudies_64.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChartStudies_64.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:52 to www.sierrachart.com:443 for request ID:52 (4) | Closed.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:54 to www.sierrachart.com:443 for request ID:54 (1) | Closed.
Received file: 3beeps.wav
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\3beeps.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:55 to www.sierrachart.com:443 for request ID:55 (6) | Closed.
Received file: AlertSound2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\AlertSound2.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: AlertSound.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\AlertSound.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:57 to www.sierrachart.com:443 for request ID:57 (3) | Closed.
Received file: Cash Reg.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\Cash Reg.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: SierraChart.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChart.exe. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:58 to www.sierrachart.com:443 for request ID:58 (4) | Closed.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:59 to www.sierrachart.com:443 for request ID:59 (1) | Closed.
Received file: High beep1.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\High beep1.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderHasBeenCanceled.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenCanceled.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:60 to www.sierrachart.com:443 for request ID:60 (6) | Closed.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:53 to www.sierrachart.com:443 for request ID:53 (5) | Closed.
Received file: OrderHasBeenFilled.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenFilled.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: SierraChart_64.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\SierraChart_64.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: OrderHasBeenModified.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\OrderHasBeenModified.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:62 to www.sierrachart.com:443 for request ID:62 (7) | Closed.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:61 to www.sierrachart.com:443 for request ID:61 (3) | Closed.
Received file: airplane.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\airplane.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: applause.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\applause.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:63 to www.sierrachart.com:443 for request ID:63 (1) | Closed.
Received file: blong2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\blong2.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:56 to www.sierrachart.com:443 for request ID:56 (2) | Closed.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:64 to www.sierrachart.com:443 for request ID:64 (4) | Closed.
Received file: buzzer2.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\buzzer2.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: honk.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\honk.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:65 to www.sierrachart.com:443 for request ID:65 (5) | Closed.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:66 to www.sierrachart.com:443 for request ID:66 (6) | Closed.
Received file: pager.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\pager.wav. Error: Windows error code 3: The system cannot find the path specified.
Received file: police-siren.wav
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\AlertSounds\police-siren.wav. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:67 to www.sierrachart.com:443 for request ID:67 (3) | Closed.
Received file: Button_10.bmp
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_10.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:69 to www.sierrachart.com:443 for request ID:69 (7) | Closed.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:68 to www.sierrachart.com:443 for request ID:68 (1) | Closed.
Received file: Button_14.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_14.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_15.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_15.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:70 to www.sierrachart.com:443 for request ID:70 (2) | Closed.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:71 to www.sierrachart.com:443 for request ID:71 (4) | Closed.
Received file: Button_157.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_157.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_16.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_16.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:72 to www.sierrachart.com:443 for request ID:72 (5) | Closed.
Received file: Button_161.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_161.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:74 to www.sierrachart.com:443 for request ID:74 (6) | Closed.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:73 to www.sierrachart.com:443 for request ID:73 (3) | Closed.
Received file: Button_163.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_163.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_17.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_17.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:75 to www.sierrachart.com:443 for request ID:75 (1) | Closed.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:76 to www.sierrachart.com:443 for request ID:76 (7) | Closed.
Received file: Button_175.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_175.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_23.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_23.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:77 to www.sierrachart.com:443 for request ID:77 (2) | Closed.
Received file: Button_247.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_247.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:79 to www.sierrachart.com:443 for request ID:79 (5) | Closed.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:78 to www.sierrachart.com:443 for request ID:78 (4) | Closed.
Received file: Button_26.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_26.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_267.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_267.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:80 to www.sierrachart.com:443 for request ID:80 (3) | Closed.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:81 to www.sierrachart.com:443 for request ID:81 (6) | Closed.
Received file: Button_27.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_27.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_28.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_28.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:82 to www.sierrachart.com:443 for request ID:82 (1) | Closed.
Received file: Button_29.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_29.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:83 to www.sierrachart.com:443 for request ID:83 (2) | Closed.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:84 to www.sierrachart.com:443 for request ID:84 (7) | Closed.
Received file: Button_299.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_299.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (6) | Connecting to IP: 46.4.97.203.
Received file: Button_3.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_3.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:85 to www.sierrachart.com:443 for request ID:85 (4) | Closed.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:86 to www.sierrachart.com:443 for request ID:86 (5) | Closed.
Received file: Button_30.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_30.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_300.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_300.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:87 to www.sierrachart.com:443 for request ID:87 (3) | Closed.
Received file: Button_301.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_301.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:88 to www.sierrachart.com:443 for request ID:88 (1) | Closed.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:89 to www.sierrachart.com:443 for request ID:89 (2) | Closed.
Received file: Button_302.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_302.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:90 to www.sierrachart.com:443 for request ID:90 (6) | Closed.
Received file: Button_303.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_303.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:91 to www.sierrachart.com:443 for request ID:91 (7) | Closed.
Received file: Button_304.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_304.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_305.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_305.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:92 to www.sierrachart.com:443 for request ID:92 (4) | Closed.
Received file: Button_306.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_306.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:93 to www.sierrachart.com:443 for request ID:93 (3) | Closed.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:94 to www.sierrachart.com:443 for request ID:94 (1) | Closed.
Received file: Button_307.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_307.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:95 to www.sierrachart.com:443 for request ID:95 (2) | Closed.
Received file: Button_308.bmp
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:96 to www.sierrachart.com:443 for request ID:96 (5) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_308.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_309.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_309.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_31.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_31.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:97 to www.sierrachart.com:443 for request ID:97 (6) | Closed.
Received file: Button_312.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_312.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:98 to www.sierrachart.com:443 for request ID:98 (4) | Closed.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:99 to www.sierrachart.com:443 for request ID:99 (3) | Closed.
Received file: Button_317.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_317.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:100 to www.sierrachart.com:443 for request ID:100 (1) | Closed.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:101 to www.sierrachart.com:443 for request ID:101 (7) | Closed.
Received file: Button_318.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_318.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_319.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_319.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_32.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_32.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:102 to www.sierrachart.com:443 for request ID:102 (2) | Closed.
Received file: Button_320.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_320.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:103 to www.sierrachart.com:443 for request ID:103 (5) | Closed.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (5) | Connecting to IP: 46.4.97.203.
Received file: Button_322.bmp
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:104 to www.sierrachart.com:443 for request ID:104 (4) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_322.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:105 to www.sierrachart.com:443 for request ID:105 (3) | Closed.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:106 to www.sierrachart.com:443 for request ID:106 (6) | Closed.
Received file: Button_323.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_323.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_324.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_324.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_325.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_325.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:107 to www.sierrachart.com:443 for request ID:107 (1) | Closed.
Received file: Button_326.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_326.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:108 to www.sierrachart.com:443 for request ID:108 (2) | Closed.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (2) | Connecting to IP: 46.4.97.203.
Received file: Button_327.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_327.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:109 to www.sierrachart.com:443 for request ID:109 (5) | Closed.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:110 to www.sierrachart.com:443 for request ID:110 (4) | Closed.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:111 to www.sierrachart.com:443 for request ID:111 (7) | Closed.
Received file: Button_328.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_328.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_329.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_329.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_33.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_33.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:112 to www.sierrachart.com:443 for request ID:112 (3) | Closed.
Received file: Button_34.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_34.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:113 to www.sierrachart.com:443 for request ID:113 (1) | Closed.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:114 to www.sierrachart.com:443 for request ID:114 (2) | Closed.
Received file: Button_340.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_340.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:115 to www.sierrachart.com:443 for request ID:115 (6) | Closed.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:116 to www.sierrachart.com:443 for request ID:116 (5) | Closed.
Received file: Button_35.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_35.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_36.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_36.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_37.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_37.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:117 to www.sierrachart.com:443 for request ID:117 (4) | Closed.
Received file: Button_39.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_39.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:118 to www.sierrachart.com:443 for request ID:118 (3) | Closed.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:119 to www.sierrachart.com:443 for request ID:119 (1) | Closed.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:120 to www.sierrachart.com:443 for request ID:120 (7) | Closed.
Received file: Button_40.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_40.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:121 to www.sierrachart.com:443 for request ID:121 (2) | Closed.
Received file: Button_41.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_41.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_43.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_43.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_56.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_56.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:122 to www.sierrachart.com:443 for request ID:122 (5) | Closed.
Received file: Button_599.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_599.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:123 to www.sierrachart.com:443 for request ID:123 (4) | Closed.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:124 to www.sierrachart.com:443 for request ID:124 (3) | Closed.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Connecting to IP: 46.4.97.203.
Received file: Button_66.bmp
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:125 to www.sierrachart.com:443 for request ID:125 (6) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_66.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:126 to www.sierrachart.com:443 for request ID:126 (1) | Closed.
Received file: Button_69.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_69.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_70.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_70.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_72.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_72.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:127 to www.sierrachart.com:443 for request ID:127 (2) | Closed.
Received file: Button_73.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_73.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:128 to www.sierrachart.com:443 for request ID:128 (5) | Closed.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:129 to www.sierrachart.com:443 for request ID:129 (4) | Closed.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Connecting to IP: 46.4.97.203.
Received file: Button_74.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_74.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:130 to www.sierrachart.com:443 for request ID:130 (7) | Closed.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:131 to www.sierrachart.com:443 for request ID:131 (3) | Closed.
Received file: Button_75.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_75.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_766.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_766.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_76.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_76.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:132 to www.sierrachart.com:443 for request ID:132 (1) | Closed.
Received file: Button_84.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_84.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:133 to www.sierrachart.com:443 for request ID:133 (2) | Closed.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (2) | Connecting to IP: 46.4.97.203.
Received file: Button_85.bmp
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:134 to www.sierrachart.com:443 for request ID:134 (5) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_85.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:135 to www.sierrachart.com:443 for request ID:135 (4) | Closed.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:136 to www.sierrachart.com:443 for request ID:136 (6) | Closed.
Received file: Button_89.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_89.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_9.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_9.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_90.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_90.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:137 to www.sierrachart.com:443 for request ID:137 (3) | Closed.
Received file: Button_92.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_92.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:138 to www.sierrachart.com:443 for request ID:138 (1) | Closed.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:139 to www.sierrachart.com:443 for request ID:139 (2) | Closed.
Received file: Button_93.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_93.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:141 to www.sierrachart.com:443 for request ID:141 (7) | Closed.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:140 to www.sierrachart.com:443 for request ID:140 (5) | Closed.
Received file: Button_94.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_94.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_96.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_96.bmp. Error: Windows error code 3: The system cannot find the path specified.
Received file: Button_95.bmp
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Graphics\Buttons\Button_95.bmp. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:142 to www.sierrachart.com:443 for request ID:142 (4) | Closed.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:143 to www.sierrachart.com:443 for request ID:143 (3) | Closed.
Received file: SciLexer.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\SciLexer.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: contextMenu.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\contextMenu.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:144 to www.sierrachart.com:443 for request ID:144 (1) | Closed.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:145 to www.sierrachart.com:443 for request ID:145 (2) | Closed.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:146 to www.sierrachart.com:443 for request ID:146 (6) | Closed.
Received file: doLocalConf.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\doLocalConf.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: functionList.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\functionList.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: langs.model.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\langs.model.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:148 to www.sierrachart.com:443 for request ID:148 (4) | Closed.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:147 to www.sierrachart.com:443 for request ID:147 (5) | Closed.
Received file: license.txt
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\license.txt. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:149 to www.sierrachart.com:443 for request ID:149 (3) | Closed.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:150 to www.sierrachart.com:443 for request ID:150 (1) | Closed.
Received file: langs.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\langs.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (1) | Connecting to IP: 46.4.97.203.
Received file: english.xml
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\english.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: english_customizable.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\localization\english_customizable.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:151 to www.sierrachart.com:443 for request ID:151 (7) | Closed.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:153 to www.sierrachart.com:443 for request ID:153 (6) | Closed.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:152 to www.sierrachart.com:443 for request ID:152 (2) | Closed.
Received file: batch.xml
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\batch.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: notepad .exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\notepad .exe. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:155 to www.sierrachart.com:443 for request ID:155 (5) | Closed.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:154 to www.sierrachart.com:443 for request ID:154 (4) | Closed.
Received file: cpp.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\APIs\cpp.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: readme.txt
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\readme.txt. Error: Windows error code 3: The system cannot find the path specified.
Received file: mimeTools.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\plugins\mimeTools.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:157 to www.sierrachart.com:443 for request ID:157 (3) | Closed.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:156 to www.sierrachart.com:443 for request ID:156 (1) | Closed.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:158 to www.sierrachart.com:443 for request ID:158 (6) | Closed.
Received file: shortcuts.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\shortcuts.xml. Error: Windows error code 3: The system cannot find the path specified.
Received file: stylers.model.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\stylers.model.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:160 to www.sierrachart.com:443 for request ID:160 (7) | Closed.
Received file: stylers.xml
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\NPP\stylers.xml. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:159 to www.sierrachart.com:443 for request ID:159 (2) | Closed.
Received file: rim_ssl_cert_auth_params
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_cert_auth_params. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:161 to www.sierrachart.com:443 for request ID:161 (4) | Closed.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:162 to www.sierrachart.com:443 for request ID:162 (3) | Closed.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:163 to www.sierrachart.com:443 for request ID:163 (1) | Closed.
Received file: rim_ssl_client_params
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_client_params. Error: Windows error code 3: The system cannot find the path specified.
Received file: rim_ssl_client_private_key
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\rim_ssl_client_private_key. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:165 to www.sierrachart.com:443 for request ID:165 (6) | Closed.
Received file: DTCBridge.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Rim\DTCBridge.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: CrashRpt1403.dll
Failed to create folder: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\. Windows error code 183: Cannot create a file when that file already exists.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashRpt1403.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: CrashRptProbe1403.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashRptProbe1403.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:166 to www.sierrachart.com:443 for request ID:166 (2) | Closed.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:167 to www.sierrachart.com:443 for request ID:167 (4) | Closed.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (4) | Creating socket. Using TLS 1.2.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (4) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:164 to www.sierrachart.com:443 for request ID:164 (5) | Closed.
Received file: RIJNDAEL.DLL
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:168 to www.sierrachart.com:443 for request ID:168 (3) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\RIJNDAEL.DLL. Error: Windows error code 3: The system cannot find the path specified.
Received file: CrashSender1403.exe
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\CrashSender1403.exe. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (3) | Creating socket. Using TLS 1.2.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (3) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:169 to www.sierrachart.com:443 for request ID:169 (1) | Closed.
Received file: TAPriceEngineAPI.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAPriceEngineAPI.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: TAOrderServerAPI.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAOrderServerAPI.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: TAWireTypesCPP.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TAWireTypesCPP.dll. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (1) | Creating socket. Using TLS 1.2.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (1) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:171 to www.sierrachart.com:443 for request ID:171 (7) | Closed.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (5) | Creating socket. Using TLS 1.2.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (5) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:170 to www.sierrachart.com:443 for request ID:170 (6) | Closed.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (4) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (6) | Creating socket. Using TLS 1.2.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (6) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (2) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Creating socket. Using TLS 1.2.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (4) | Socket gracefully closed by remote side.
HTTPS connection ID:173 to www.sierrachart.com:443 for request ID:173 (4) | Closed.
Received file: TransactToSierraBridge.exe
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:172 to www.sierrachart.com:443 for request ID:172 (2) | Closed.
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\TransactToSierraBridge.exe. Error: Windows error code 3: The system cannot find the path specified.
Received file: aesc.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\aesc.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: crashrpt_lang.ini
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\crashrpt_lang.ini. Error: Windows error code 3: The system cannot find the path specified.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (3) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (2) | Creating socket. Using TLS 1.2.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (2) | Connecting to IP: 46.4.97.203.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (3) | Socket gracefully closed by remote side.
HTTPS connection ID:174 to www.sierrachart.com:443 for request ID:174 (3) | Closed.
Received file: xerces-c_3_1.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\xerces-c_3_1.dll. Error: Windows error code 3: The system cannot find the path specified.
Received file: zlib1.dll
Failed to open the file: C:\Users\User\Desktop\DownloadedInstallationFiles\Transact\zlib1.dll. Error: Windows error code 3: The system cannot find the path specified.
Error saving downloaded files to local system. Stopping installation. Check log.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (1) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (1) | Socket gracefully closed by remote side.
HTTPS connection ID:175 to www.sierrachart.com:443 for request ID:175 (1) | Closed.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (6) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (5) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (6) | Socket gracefully closed by remote side.
HTTPS connection ID:177 to www.sierrachart.com:443 for request ID:177 (6) | Closed.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (5) | Socket gracefully closed by remote side.
HTTPS connection ID:176 to www.sierrachart.com:443 for request ID:176 (5) | Closed.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Shutdown started. Waiting for graceful close.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Socket gracefully closed by remote side.
HTTPS connection ID:178 to www.sierrachart.com:443 for request ID:178 (7) | Closed.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (2) | Socket gracefully closed by remote side.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
HTTPS connection ID:179 to www.sierrachart.com:443 for request ID:179 (2) | Closed.
Sierra Chart Support
[2019-03-15 21:55:16]
You have installed Sierra Chart into the wrong folder:
You need to delete that installation from your desktop. But if you have been using it, then you need to take a copy of your Chartbook files in the Data subfolder.
You need to install Sierra Chart to C:\SierraChart.
Date Time Of Last Edit: 2019-03-15 21:55:41
