Date/Time: Sun, 05 May 2024 15:57:47 +0000
[Programming Help] - Quote spreadsheet in Excel
View Count: 1029
[2019-03-14 00:02:13] |
User294224 - Posts: 43 |
Is it possible open a quote spreadsheet in Excel? I am looking to draw a line of best fit through data some data points to create a real time futures curve and I don't believe this is supported in the sierra chart spreadsheet |
[2019-03-14 00:47:50] |
No it is not. For the functions supported in Sierra Chart spreadsheets, refer to: Spreadsheet Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-14 09:10:56] |
Ok, Are any of these functions capable of fitting a line of best fit to my data? What I am interested in is the difference between the line of best fit and each data point. Perhaps the FORECAST function? |
