Date/Time: Thu, 02 May 2024 17:55:20 +0000
Unable to get time set correctly on second computer
View Count: 523
[2019-03-12 15:47:06] |
User265865 - Posts: 1 |
Unable to get time set correctly on second computer. I have tried the different methods suggested in the help manual.
[2019-03-12 17:05:01] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Select this command from the menu: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) After that provide the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
