Date/Time: Wed, 01 May 2024 15:32:59 +0000
Multiple Volume profile settings
View Count: 1233
[2019-03-12 14:24:25] |
User798235 - Posts: 10 |
Hi! when assigning VP to a button it only saves the one that is default, and it works but i want to have more than one and have 1 button for each, how do i achiev this?
[2019-03-12 17:56:32] |
Ok so it sounds like you are referring to a control bar button. What is the default name of that control bar button? The name as it is listed in Global Settings >> Customize Control Bars >> Control Bar #.
[2019-03-12 18:12:16] |
No not really, i mean when i add a button to my controlbar 1 i can assign diffent setting for rectangles and lines, have multiple buttons with different setting. My problem is that im not able to do that with a volume profile button, it only takes settings from the default file //mag |
[2019-03-13 01:02:29] |
The first step is to configure a Volume Profile drawing tool configuration as explained here: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool Then you can use that particular configuration number with the Control Bar button: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-13 01:18:45
[2019-03-13 06:19:42] |
aah it was the save study collection part i didnt get! resolved now, thank you very much!!
