Date/Time: Fri, 03 May 2024 09:19:18 +0000
Numbers bars calculated values
View Count: 4183
[2019-03-08 14:54:08] |
nosast2 - Posts: 73 |
I just noticed with the update of 1882 that the numbers format have changed. I would like to have the option (at least with Delta %) to not show the percent sign and also see this rounded to decimal places. Prior to that version I used 1875 and didn't have this issue. Thanks Norman |
2019-03-08_15-51-17.png / V - Attached On 2019-03-08 14:53:59 UTC - Size: 4.26 KB - 526 views |
[2019-03-08 21:53:18] |
John - SC Support - Posts: 31334 |
Yes, we made a change to this as there was a potential issue when using the Larger Integer with Suffix option. We will see what we can do to allow both options for the Value Format. How many decimal places do you want to have displayed? In previous versions there were no decimal places displayed at all. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-08 22:08:32] |
I would love to have the ability to set it up like in the previous version. See attached pic of 1880. Actually no decimal places and no "%-sign".
2019-03-08_23-07-05.png / V - Attached On 2019-03-08 22:08:27 UTC - Size: 2.6 KB - 470 views |
[2019-03-11 16:05:46] |
We have added an Input to the Numbers Bars Calculated Values that will allow you to have the Percentage values formatted either as a Percent (2 decimal places plus the % sign) or using the Default Value set in the Value Format for the study. The Input is named Use Default Number Formatting for Percentages. You will find the documentation on this Input here: Numbers Bars: Numbers Bars Calculated Values Input Descriptions This will be in the next Pre-Release (v 1883). When it is available, you can update using the Fast Update option. The documentation for this can be found here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-14 19:19:06] |
This is fixed in 1883. Thanks
