Date/Time: Sun, 19 May 2024 21:02:12 +0000
Hiding the drawings and just keeping the labels.
View Count: 1114
[2019-03-06 12:25:04] |
User541156 - Posts: 67 |
I am trying to just keep the labels, but hide the drawings of some indicators. Have a look at the image. I just want to keep this POC label, but hide the line. In order to hide the line, I changed the Width Size to 0, but it still leaves a thin black line. If I try to use Draw Style Hidden or Ignore, this label also goes away, which I don't want. What settings can I use to keep the label, and completely hide the line? Thanks. Date Time Of Last Edit: 2019-03-06 12:26:59
2019-03-06_22-49-38.png / V - Attached On 2019-03-06 12:25:22 UTC - Size: 61.66 KB - 322 views |
[2019-03-07 01:27:04] |
You need to use this particular Draw Style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
