Date/Time: Sun, 13 Jul 2025 06:45:07 +0000
Memory Leak on Windows 7
View Count: 1016
[2019-03-05 13:53:49]
User75002 - Posts: 117
I am experiencing what I believe is a memory leak in Sierra running on Windows 7 in a VirtualBox environment.
Background:
Over the weekend I rebuilt my Windows 10 system with Linux and am using VirtualBox to run a Windows 7 64bit system for Sierra. Windows 7 was given 4vCPU and 8GB memory. On Windows 10 I was running 1875 and on the Windows 7, I installed the latest 1880 version. Since then I have had my memory usage slowly increase, more so when the market data volume increases or maybe just when I am more actively using it. On initial reboot and load of Sierra, Sierra claims to use about 250MB and total system usage is about 1.5GB. Last night, I looked at my total system memory usage after running all day and it was at 4.3GB, but Sierra was only showing 270MB. I then closed Sierra and the memory went from 4.3GB to 1.5GB. When I started Sierra again, I noticed the memory jumping around between 1.8GB and 3.8GB. I never noticed this on my Windows 10 system. After the chartbooks were opened and data downloaded, it returned to 1.8GB. This morning (7am EST), I looked at the system and it was at 2.3GB. About an hour later (8:30am EST now) after I went through and looked at the charts for the morning, it is at 3.3GB. Nothing else is on this computer except for the Gain Capital OEC platform.
I don't know if this is an issue with 1880, Windows 7 or it running under VirtualBox, but would like your input and thoughts, maybe some things to try to isolate further? I will try to roll back to 1875 now and see if I continue to have the problem throughout the day. When I closed Sierra to roll back my memory usage went from 3.3GB to 1.3GB. After rebooting and starting 1875, my memory went from 900MB to 2.8GB. I will play around with closing some chartbooks to see if one of them may be corrupted and update the post later.
Kind Regards,
Kevin
[2019-03-05 14:13:59]
I closed all of my chartbooks one at a time and gained 1GB back closing the NQ chartbook. I then excluded that from loading on startup, thinking it was corrupted, but still went from 1.6GB to 2.7GB after running. Outside of Sierra, the Windows 7 is functioning as expected.
[2019-03-05 17:47:54]
There is no memory leak in Sierra Chart at all. What you are seeing is most likely caching of the intraday data file data by the operating system.
[2019-03-05 17:56:55]
Is there anyway to disable the caching of the intraday data on Windows 7? I didn't experience this at all on Windows 10 the last 2 years nor on Windows 7 previously, but they were physical installs, not virtual.
Thanks.
[2019-03-05 18:06:45]
We are not aware of a setting for this.
We are not aware of a setting for this. But what it is doing is not really a bad thing. Just make sure you have enough memory. We would think it would be a good that the data is in memory and can be quickly accessed.
Date Time Of Last Edit: 2019-03-05 18:07:21
