Date/Time: Sun, 19 May 2024 04:36:52 +0000
Opening a new menu window takes very long time.
View Count: 525
[2019-03-04 19:25:04] |
User736519 - Posts: 26 |
Running latest version of SC on CQG webapi. Opening a menu window(eg: Global Settings >Chart trade settings) takes very long time to show up the menu window.
[2019-03-04 19:38:25] |
This means Sierra Chart is using a high amount of CPU time based on your configuration. Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
