Date/Time: Sun, 19 May 2024 03:48:15 +0000
Hiding or showing the chart values below the toolbar
View Count: 856
[2019-03-02 19:05:11] |
trader1 - Posts: 128 |
Hi, Can you please tell me how to add or remove values and hide or display the values that appear directly below the toolbars on the chart window? By this I mean the values like symbol, bar period,DChg,H,L,O,V,C etc. (I have attached a screen shot of the area I am referring to). Thanks. |
SierraChart chart values labels.png / V - Attached On 2019-03-02 19:03:15 UTC - Size: 32.56 KB - 300 views |
[2019-03-02 22:43:25] |
Refer to: Working With Charts: Region Data Line / Chart Header (Region Data Line / Chart Header) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-02 22:43:53
